It is currently Fri Aug 22, 2025 9:03 am
PostPosted: Sun Aug 18, 2013 10:42 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Building my first 8 string 12 fret to the body.Think I will use 44mm at nut an 54 at the body.Never made one or have access to one.Is this too big ,or small ? Also using a small 1/4in x1/4in7 fan mahog bracing with a bridge plate.thanks
PostPosted: Sun Aug 18, 2013 8:18 pm
First name: Rusty
What does your plan call for? If you don't have a set of plans, i believe Hana Lima Ia has pineapple uke plans.
Sent from my iPhone using Tapatalk 2
PostPosted: Mon Aug 19, 2013 8:15 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
I don/t have plans, The uu forum responder said a tad smaller than reg tenor sized nut i.e. 36-38mm and 46-48 at the body.
PostPosted: Mon Aug 19, 2013 8:30 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I haven't done an 8 string before.....but all the specs I see for Martin taropatch ukes say 1.5" at the nut
PostPosted: Mon Aug 19, 2013 9:19 pm
City: winnipeg
State: manitoba
Country: canada
That would be 38 at the nut. Is that actual nut length or is that outside to outside of the strings?
My latest tenor is 35 mm nut length (zero fret) and 27.5 mm string O-O (Four strings).
Bob :ugeek:
PostPosted: Tue Aug 20, 2013 6:08 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
I checked on the UU forum some models around 38 and others slightly larger around 1.6in or 40mm
